Greasing Branson 3510i
/ Greasing Branson 3510i #1
Yalerider
Woodland, Washington
Branson 3510i w/FEL
I have a new NAPA grease gun and when I grease my tractor the hose is really hard to get off of the grease nipples. I've never had issue like this before. Is there a trick to this?
/ Greasing Branson 3510i #2
Yes, there's a trick to it. I'm not sure now of the correct terminology, but the end piece that goes onto the grease fitting has something like some little fingers in it and the outer part that screws onto it adjusts how tight they fit. Is that confusing enough? /forums/images/graemlins/crazy.gif In other words, unscrew the end a little bit to loosen it up.
/ Greasing Branson 3510i #3
Thanks Bird,
I just ran into the same thing while greasing the 4-wheeler. Didn't know I had screwed it up tight, but guess I must have.
/ Greasing Branson 3510i #4
Mine works the same way, cant find a happy spot with it either
should have throwed it out a long time ago.
I have to tighten & loosen it each time /forums/images/graemlins/crazy.gif
Gene
Thanks, I will give it a try. I figured it wasn't the grease gun as it seems like a a good one.
/ Greasing Branson 3510i #6
Yalerider,
Does that mean you are going to throw out the Branson,--and keep the Grease Gun??? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
dancce
2023 Ford Explorer SUV (A66738)
2023 Ford Explorer...
340 GAL WATER TANK (A68842)
340 GAL WATER TANK...
2002 Haulmark KD7X16WT2 12ft. T/A Enclosed Air Cascade Trailer (A66738)
2002 Haulmark...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
kobota mx5400 for sale
2014 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2014 FORD F150...
