greasing 54c deck
/ greasing 54c deck #1
newbomb_turk
Pacific Northwest
JD 2305
I have a 4-year old 54c deck, and I religiously maintain/grease it. It works great. However, now the grease will not push through the bearings to the underside of the deck. It just squirts out of the top of the spindle, and makes a heck of a mess under the pulleys. What do I need to do to fix this?
Hate to disassemble the whole thing, but it sounds like I may need to do just that.
Thanks,
Todd
/ greasing 54c deck #2
Sounds like you have a grease gun problem. The end that snaps onto the zerk on the mower deck eithers needs tightening or replaced. Hoild the end with your hand and see if the serrated tip will tighten up. If tight it is worn and needs replacing. Look for a replacement with three or more retention fingers in the end that snaps onto the zerk.
/ greasing 54c deck
No, it doesn't squirt out at the zerk (which is on top of the pulley). The grease squirts out under the pulley. I can't see exactly where it is coming from, because there is only about 1/2" space between the pulley and the deck.
Todd
/ greasing 54c deck #4
Sounds like you have over-greased it. Any chance of that?
Maybe twice a year, I pump in 5-10 pumps of grease into the spindles of my 54" decks.
But sounds like you need to remove the pulley on one and drop out the spindle shaft to see if it is overloaded with grease. There is quite a cavity in there. Plan to change out the seals and be careful not to blow them out with grease (if that ends up being the problem).
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
2000 Volvo Semi Truck (A66285)
2000 Volvo Semi...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
MASSEY FERGUSON 1838 IN-LINE SQUARE HAY BALER (A64277)
MASSEY FERGUSON...
Ammann AV33E Roller (A65579)
Ammann AV33E...
Onan HomeSite Power 6500 Generator (A66408)
Onan HomeSite...
