Grease?
/ Grease? #1
meos1
York, SC
Kubota BX2370-1
So I am coming up on the first 10 hours on a new tractor. I went and got a pneumatic grease gun for the job. I bought the red high temp grease but I was wondering if anyone is using a different type grease and why?
/ Grease? #2
I use grade 0 grease for mower decks. It melts into a really thick oil. I used to have trouble with the towers going out. Haven't had an issue since. I use the hi temp for every thing else.
/ Grease? #3
as frequently as we add grease to the fel and bh, just about any good grease will work fine for them. It's not like they are highspeed like wheel bearings and require a heat tolerant grease, they don't. If the grease is slippery, that's about all you need to worry about.
/ Grease? #4
I use boat trailer wheel bearing grease on everything. Is not supposed to "wash out." I do grease often.
/ Grease? #5
What kind of pneumatic dispenser did you go with? Let us know how it works.
I don't like doing it the old fashioned way but am too cheap to go buy a Dewalt cordless grease gun.
/ Grease? #6
I bought a 5 gal bucket of Kubota grease (the aqua-blue colored stuff). When greasing the loader every 10 hours, I was going through enough tubes that I realized it made more sense to buy the lifetime supply bucket.
/ Grease? #8
We use a couple different greases. Things that get lubed often and not under a lot of load get a cheap grease. Everything else gets a Redtac or Lubriplate grease. Wheel bearings only get Lubriplate
Edit: Things that must turn frequently when cold (augers) also get the cheap grease during winter and better grease during summer.
/ Grease? #9
Frequent application of the wrong grease is better than infrequent application of the right grease. Personally I use molly grease, the nasty black stuff with molybdenum in it.
With open sloppy joints like loaders & what not you are driving contaminants like me dirt & sand out when you grease as much as you are putting in new lube.
/ Grease? #11
newbury... you beat me to it. Highly recommend as will many others here. Believe it or not, it makes zerk greasing fun!
I call BS on that. I'm glad I got one though. It definitely makes greasing suck a lot less.
/ Grease?
Its a Campbell-Hausefeld single dose dispenser. It takes a cartridge or bulk. The old gun was a leveractionmy father owned and was a bear at times. Since I have air I decided it was time.
/ Grease? #13
I have been getting the mobil one synthetic grease lately. Seems like a good all around grease for everything. It's pricey but the little that I go through in a year makes little difference. If I owned a construction company and were going through tubes a day I would look more into purpose-made grease for different applications. Or if I had a boat trailer I would buy specific marine grease, though the mobile 1 may be rated for that as well. My next choice would be mobil xhp222.
Just be careful for compatibility issues, as some greases aren't compatible with others. I think this especially applies to moly greases.
On a side note, we have a few lincoln pneumatic guns at work collecting dust because they have for the most part gone to bulk grease with pneumatic pumps on barrels. They still have a few specialty greases in tubes, but we just use manual guns for that. One of these days those guns will probably be tossed and end up taking a ride to my garage.
/ Grease? #16
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2013 International DuraStar 4300 General Cable T40-C 35ft. Bucket Truck (A64194)
2013 International...
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
HARDEE 16' T/A TILT BED TRAILER (A64278)
HARDEE 16' T/A...
Bigfoot Yard Art (A64557)
Bigfoot Yard Art...
