Grease Zerks
/ Grease Zerks #11
just a little interesting fact about grease fittings, i was reading thru a book published in the 60s called "moving the earth", its all about earthmoving machinery and covers maintenace type stuff too, and in the part where it was talking about grease it showed the two types of grease fittings, the zerk and the hydraulic fitting, the picture of the hydraulic fitting was what we usualy refer to as a zerk fitting, while the true zerk fitting was the actual old style ones that didnt have a head on them, just a little tapered nipple, looks very simular to a zerk but doesn lock the gun on so you need to push the gun onto it the whole time your pumping. just thought it was interesting that what we usualy refer to as a zerk isnt actualy a zerk
/ Grease Zerks #12
My 1960's earth moving equipment had button fittings on the pivots. You slipped onto them sideways and the gun tip locked into place. A few squirts and you took it off. My 1934 Dodge has the type of fittings that you refer to.
/ Grease Zerks #13
Did you guys also know that they make Zerk caps to keep the dirt out of your Zerk's?
/ Grease Zerks #14
</font><font color="blue" class="small">(
I noticed that some areas brownish grease came out when I greased where in other areas it was black. I assume the brown grease maybe has moisture in it? Do I need to keep pumping until all the brownish grease is forced out?
)</font>
If the grease is coming out brown it may have water in it. If this is a "new" 8N for you I would recommend that you pump grease through until you see new grease coming out. That will help flush out any water and old crud that is in there. A little messy, but worth it to be sure everything is greased properly.
You dealing with a tractor that is at least 52 years old so a good round of maintenance is in order.
BTW, when you change the oil filter you need to use some paper towels and clean out the bottom of the filter housing, probably gunk trapped in the bottom of it.
Don't forget to remove the air filter, wash it out with solvent and fill it up to the "Oil" mark with 30 W motor oil.
Marvelous old machines. I have owned 2 of them and sometimes wish I had kept the last one as a spare for my new Kubota B7510. It was actually better for some chores than the B7510 is.
Besides that the 8N"s LOOK like a tractor!
Bill Tolle
/ Grease Zerks #16
Bill I have never used one of those grease joint cleaning tools but I have seen them before. Do they actually do what they claim? In the past if replacing a zerk didn't fix the problem I have always found that the pin or grease joint needed to be disassembled to be cleaned properly anyhow.
/ Grease Zerks #18
For $34.99 plus shipping, I can buy a two lifetime supplies of grease fittings.
/ Grease Zerks #19
Northern Tool has 2 cleaners - one is a $24.99 pocket model.
/ Grease Zerks #20
Daryl I'm not even sure where Maumee is. I use the Harbor Freight on Manchester Road in South Akron. Our place is only about 15 minutes south of that point. Harbor Freight is kind of a home away from home for me.
Junkman I agree that you can indeed buy a lot of zerks for 40 bucks but I was just curious to see if the tool actually saved you having to dismantle the whole assembly in a pinch. It's not the jerk that takes time to replace as much as the time it takes to disassemble the grease joint/pin if the new zirk still won't take the grease. I normally find that if it's that bad the pin is full of mud or grit anyway and really needs to be manually disassembled and cleaned out.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2008 Regal 2565 Express Cruiser Boat with 30ft T/A Continental Boat Trailer (A59231)
2008 Regal 2565...
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2017 BX2680 Sub Compact Utility Tractor (A61307)
2017 BX2680 Sub...
1998 JOHN DEERE 120 EXCAVATOR (A62129)
1998 JOHN DEERE...
