Grease on 3PH pins, good or bad idea?
   / Grease on 3PH pins, good or bad idea? #11
When they are new and sticky, I spray them down but after that I have always left them dry. When I worked at a dealership we never greased them or had any customer that I knew of ask about having them greased. Never did see any come in that had grease there either. Almost all types of lube will attract dirt and wear the balls and sockets out.
EDIT: I thought it said balls but it said pins. But, anyway I have never greased them either.
   / Grease on 3PH pins, good or bad idea? #12
I'll use a spray lithium grease. Once it dries, it provides a little bit of rust prevention.
   / Grease on 3PH pins, good or bad idea? #13
I use a spray on grease every time I change attachments / BH. But I wash the old grease and dirt off first with Brake Parts Cleaner, then let it dry before reapplying the new cote of grease. Not sure it really makes a difference, but it does make me feel better!
Gary
   / Grease on 3PH pins, good or bad idea? #15
Bob_Young said:
That hitch ball comment was interesting, zzvy. I started greasing mine to get rid of the GRROOOAAAANNNs when I went around a corner or, especially, up and over a steep hump. Never noticed any difference in stability.
Bob
Ditto. We use moly wheel bearing grease on the gooseneck 2 5/16" hitch ball for our horse trailer. Keeps it quiet, smooth, and free of rust. Stability is flawless. Before we started greasing it it was kinda noisy. I just think about how much force can be on that ball and wonder how fast it would wear without lubrication.
   / Grease on 3PH pins, good or bad idea? #16
I have all my implement pins dry. What a mess if they were all lubed up.:eek: I would have to say that I can not remember ever seeing implement pins lubed. My guess would be if they were supposed to be greased that they would come with zerk fittings in the implements. There most likely is a reason that they don't, just not sure what that reason is other than it would be really messy.;)
   / Grease on 3PH pins, good or bad idea? #17
tallyho8 said:
I have a can of spray silicone I use on mine. I don't know how good a job it does but it doesn't seem to attract a dirt buildup.
Tallyho8, I think you hit the pin on the head.:D :D
spray on silicone attracks no dirt cause it wont stick to it, I have been using it for years on the advice of an old farmer.
He said NEVER use grease !:eek:
   / Grease on 3PH pins, good or bad idea? #18
Personally I don't like grease because it attracts so much dirt. I use a Moly dry film lubricant. It provides a good solid film lubrication that does not attract dust and dirt.
   / Grease on 3PH pins, good or bad idea? #19
zzvyb6 said:
I use wd-40 on it, a bit lighter than grease. Only thing you NEVER want to grease is a trailer hitch ball, and I see it all the time. Friction in the hitch is a major stabilizing factor, just like the extra hitch friction brake, you don't want to lubricate it.
I disagree.
This is the first I've heard of this. In fact. if you have trailer stability issues, then you have trailer / load problems.
Grease the ball and minimize wear on the ball and hitch. Also, keep the locking assembly lubed for easier attachement and less wear.
We also grease the GN ball for the groan issues as well as wear. There can be a lot of weight on a ball - you dont wan thtis to be a dry joint.
No if you have WD hitch and sway control - you DO NOT want to lubricate the sway control friction assembly...
   / Grease on 3PH pins, good or bad idea? #20
Oh yea - I use motor oil to lube the 3pt balls - easy to do and WAY BETTER than having a dry assembly - which will be metal on metal - don;t worry too much about the dirt - the tolerances are not that tight.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
1996 Monon 45X96 Dry Van Trailer (A51039)
1996 Monon 45X96...
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2017-2023 Chevrolet Silverado Pickup Truck Bed (A49461)
2017-2023...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
