Grease Guns - Who makes one worth a flip
   / Grease Guns - Who makes one worth a flip #31
I have the Lincoln pistol style too. Probably just like yours. The only problem I have is greasing some pillow block bearings. It seems the end doesn't fit the grease zerks tight enough and grease winds of squeezing out around the zerk. I tried to change ends with an older two handed gun I have but I guess the Lincoln has metric threads. Anyway, they wouldn't interchange. I have a Lincoln cordless and the end doesn't fit the zerks tight enough either.
   / Grease Guns - Who makes one worth a flip #32
   / Grease Guns - Who makes one worth a flip #33
Does anyone have Lincoln Lubrication model # 1134? it has a pistol grip which looks like it would be easy to use with one hand. I have a pump type and it takes 2 hands to use one to hold the gun and the other to pump the handle. For $33 it will not break the bank. /forums/images/graemlins/grin.gif Any other suggestions, for a non battery, non-air grease gun?
web page
   / Grease Guns - Who makes one worth a flip #34
web page
   / Grease Guns - Who makes one worth a flip #35
Before moving back to town, I had an Alemite pneumatic grease gun with a flexible hose from Tractor Supply Co. that worked just fine. But now the only thing I have to grease is 4 fittings on the front end of the little ZTR, so I have a cheap little pistol grip grease gun, and it, too, works just fine.
   / Grease Guns - Who makes one worth a flip #36
   / Grease Guns - Who makes one worth a flip #37
The one handed grease guns are good but the handles on the ones I had bend after a while.I have some tight grease fittings on my hoe and that is what does them in.The lincoln cordless is by far the best gun out there.I tried one of the generic cordless and they dont compare.
   / Grease Guns - Who makes one worth a flip #38
   / Grease Guns - Who makes one worth a flip #39
</font><font color="blue" class="small">( Does anyone have Lincoln Lubrication model # 1134? it has a pistol grip which looks like it would be easy to use with one hand. I have a pump type and it takes 2 hands to use one to hold the gun and the other to pump the handle. For $33 it will not break the bank. /forums/images/graemlins/grin.gif Any other suggestions, for a non battery, non-air grease gun?
web page )</font>
Yep. That's the one I mentioned a few posts back. It seems to be a very nicely made unit, and is good value for the money.
   / Grease Guns - Who makes one worth a flip #40
web page )</font>
LeeBoy 685 Grader (A47477)
LeeBoy 685 Grader...
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
2011 New Holland Boomer 90 MFWD Utility Tractor (A55302)
2011 New Holland...
2012 International 7500 (A53314)
2012 International...
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A56129)
2011 FREIGHTLINER...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
