Grease gun thread size?
/ Grease gun thread size? #1
PETDOC
I've got a standard manual grease gun with a short pipe (~1") and want to replace it with longer one. I've tried to remove it, but it is stuck. I decided to either get 2 small nuts and twist them on against one another then use a wrench on the inner one to unscrew pipe or get a connecting nut to just add the extension. I can't determine the thread size on the pipe. Closest I've come to getting a match is an M10-1.0, but even that binds up after about 3 turns. Anyone know what the thread size is on standard grease gun fittings?
/ Grease gun thread size? #2
1/8" NPT
Thanks for replies. Went to Lowes plumbing isle and got a brass connector for $3.
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
(2) RAM 7000 LB TRAILER JACKS (A64280)
(2) RAM 7000 LB...
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
(2) UNUSED 23X8.50-16 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01121 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
