Grease Fittings
   / Grease Fittings #1
Captain Ned
Colchester, VT
I'd like to have a word (or 42) with whatever accountant decided that press-fit grease fittings would save a few pennies over tapped/threaded fittings. In lubing up my GT2544's deck, two of the bleeping things have come out with the grease gun. Oh well, this will be the 3rd trip to the dealer for this round of PM.
Trip 1: Buy PTO/deck belt & air filter
Trip 2: Return air filter because it's the wrong one even though my slip has the right part #
Trip 3 (so far): Buy cheap grease fittings that are unobtainium in local car parts stores because cars all use threaded/tapped fittings.
   / Grease Fittings #4
my dealer said to put a punch in the opening and give it a few taps to form a lip at the contact point. i havent had any problems yet with grease fittings yet on my 12 yr old 3185. im assuming theyve all been replaced at this point.
   / Grease Fittings
To my mind using self-tapping fittings will introduce metal shavings into the bearing. If not, I'd certainly like to avoid the alternative, which would be disassembling every bearing with a fitting, tapping it, cleaning it, and repacking it.
   / Grease Fittings #6
That must be MTD that is doing that. Maybe send them a note.
   / Grease Fittings #7
I used to keep an assortment of SAE and metric grease zerks, all threaded of course. But when I lost a pressed in fitting, I'd take one of the threaded ones, and grind the threads down a bit on my bench grinder, then take a socket wrench (just the socket) of the right side to put the grease fitting into it to protect it, line it up carefully, and one quick fairly hard blow with a hammer to drive it in and I never lost one of those then.
   / Grease Fittings #8
Exactly. Peen it on opposing sides with a punch. If you're replacing it with another press-in, apply some Loctite, then peen. In 5yrs, I never lost one on my Cub 2544. Lucky I guess.
Joel
   / Grease Fittings #9
that sounds better, hit it around the hole. as far as pulling apart a bearing and repacking, i guess that comes down to how much spare time you have.
   / Grease Fittings
Joel
OK, I'm seeing what I think are 2 separate ideas. You're suggesting that once the fitting is in, an application of a punch at two points to squeeze the hole tighter is the way to go. Highboy1975's dealer idea seems to be to punch in the hole itself to create a ridge in the hole.
I think I like your idea better. Only lost 1 more today while finishing the lube job; this one on a steering knuckle.
Before I understood that these were press-fits, I bought an assorted kit at AutoZone where I got 70 pieces for $12.99. I paid $2.06 per at the dealer this afternoon.
2014 Ford Escape SUV (A55758)
2014 Ford Escape...
2016 Ford Escape SUV (A55758)
2016 Ford Escape...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
