Grease Fittings
   / Grease Fittings #11
i think with either idea, your looking at hitting it before you put the grease fitting in to cause more of an interference fit. i was told to use a ratchet extension to tap the grease fitting in. 1/4 inch i believe. if doing it inside the hole would create a ridge, then i like my idea. the idea of peening around the hole sounded better. i was tired and not thinking my thoughts through and that using a punch inside the hole would just open it up more. you want to close the hole up a tiny little bit to give more interference between the fitting and the opening. i would think you'd have to use a pretty blunt punch to create a lip inside the hole. either way should work, it just depends on the tools you have available.
   / Grease Fittings #12
A few months ago, I had to replace a number of press-in grease fittings on my GT3235.
I went down to my local Menards home improvement center (not sure if those are by you) and found a variety of grease zerks in their specialized parts bins.
If I recall correctly, the 3/16" press-in they had was too big or two small, but when I went one size bigger/smaller, it fit perfectly.
Can't remember the price, but it was < $1 each... maybe $0.60 each.
Pick up a couple extra... sometimes when I tapped them in, I damaged the head. Make sure you use just enough force (not too much) to seat the zerk and tap squarely & evenly over the head.
All and all... it was pretty easy. Replacing with press-ins made sense -- no risk of thread shavings by tapping/installing threaded zerks. Plus no risk of me screwing it up. :)
   / Grease Fittings #13
I never tap directly on the grease zerk. Instead I take a small socket wrench just big enough to go over the part of the zerk that the grease gun attaches to, but not the base of the zerk. Then I tap on that socket so the rim of the socket drives the base of the zerk. For me, that's easier to keep it straight and I can't damage the zerk.
   / Grease Fittings #14
To my mind using self-tapping fittings will introduce metal shavings into the bearing. If not, I'd certainly like to avoid the alternative, which would be disassembling every bearing with a fitting, tapping it, cleaning it, and repacking it.
In my mind most grease fitting on a lawn mower are not on bearings only bushing.
   / Grease Fittings #16
Everyone should have a carbide tipped mining bit (single point), they are the best indexing punch ever devised...work great for dimpling. Got a couple from a friend of mine who works in the mining industry.
2020 Kubota BX23S TLB Compact Tractor (RIDE AND DRIVE) (A50775)
2020 Kubota BX23S...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2002 International 4300 DT466 (A53314)
2002 International...
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
2004 John Deere 310G 4x4 Loader Backhoe (A55787)
2004 John Deere...
2012 PETERBILT 388 DAYCAB (A55745)
2012 PETERBILT 388...
