grease fittings
   / grease fittings #1
mfc1010
ma
05 kubota 7610 tlb
Is there a tool to remove brocken grease fittings.
Mike
   / grease fittings #2
Some grease fittings are pressed in but most are right hand threaded.
A small ez-out always worked for me. Can be purchased at any auto parts store.
   / grease fittings #3
Reverse twist drill bits...as it starts biting in they start unthreading.
   / grease fittings #4
Yes, there is a grease fitting tool. It looks like a plus sign. It has a tap, easy out, and 2 "sockets" for different size grease fittings. Put the easy out side into the broken grease fitting and hammer on the tap end to tighten it, then grab it with a pair of pliers and remove the broken piece. Go into a good auto parts store and ask for a grease fitting tool. I know Lincoln makes a good one. Good luck.
Andy
   / grease fittings #5
TSC carries those t-shaped tools WCH mentoned.
both in sae and metric.
has a thread chase as well as fluted extractor and wrench ends,.. ends even accept the 90' and 45' type zerks.
soundguy
   / grease fittings #6
   / grease fittings #7
And there they are.
good job with the pics scooby074.
soundguy
   / grease fittings #8
You can usually buy these specialty tools at your local parts store.
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
2009 Ford Escape Hybrid SUV (A50324)
2009 Ford Escape...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
John 4 x 4 cart (A50323)
John 4 x 4 cart...
2013 Hyundai Sonata Hybrid Sedan (A50324)
2013 Hyundai...
