grease fittings
   / grease fittings #1
mfc1010
ma
05 kubota 7610 tlb
Is there a tool to remove brocken grease fittings.
Mike
   / grease fittings #2
Some grease fittings are pressed in but most are right hand threaded.
A small ez-out always worked for me. Can be purchased at any auto parts store.
   / grease fittings #3
Reverse twist drill bits...as it starts biting in they start unthreading.
   / grease fittings #4
Yes, there is a grease fitting tool. It looks like a plus sign. It has a tap, easy out, and 2 "sockets" for different size grease fittings. Put the easy out side into the broken grease fitting and hammer on the tap end to tighten it, then grab it with a pair of pliers and remove the broken piece. Go into a good auto parts store and ask for a grease fitting tool. I know Lincoln makes a good one. Good luck.
Andy
   / grease fittings #5
TSC carries those t-shaped tools WCH mentoned.
both in sae and metric.
has a thread chase as well as fluted extractor and wrench ends,.. ends even accept the 90' and 45' type zerks.
soundguy
   / grease fittings #6
   / grease fittings #7
And there they are.
good job with the pics scooby074.
soundguy
   / grease fittings #8
You can usually buy these specialty tools at your local parts store.
2013 FORD F-550 SUPER DUTY XL BUCKET TRUCK (A51243)
2013 FORD F-550...
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
Homemade Water Trailer 1100-gallon tank (A52128)
Homemade Water...
2015 John Deere 135G Hydraulic Excavator (A50322)
2015 John Deere...
