Grease Fittings Not Taking Grease
   / Grease Fittings Not Taking Grease #11
The small amount of dirt that might be forced into a bearing with a rejuvanator or whatever the name of the tool you use to clear a plugged Zerk can be flushed out with a generous applicationof grease. Many times it isn't just the fitting that is clogged but the internal channels in the shaft or bushing as well. Replacing the fitting won't solve that problem but the hydraulic action of the tool will.
   / Grease Fittings Not Taking Grease #12
I've also had good luck removing the zerk and using a small drill bit to clean out the passage. Pump some grease through the zerk while it is off to clear it.
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
1800 (A58375)
1800 (A58375)
1998 PETERBILT 379 (A58214)
1998 PETERBILT 379...
