Grease Fittings Not Taking Grease
   / Grease Fittings Not Taking Grease #11
The small amount of dirt that might be forced into a bearing with a rejuvanator or whatever the name of the tool you use to clear a plugged Zerk can be flushed out with a generous applicationof grease. Many times it isn't just the fitting that is clogged but the internal channels in the shaft or bushing as well. Replacing the fitting won't solve that problem but the hydraulic action of the tool will.
   / Grease Fittings Not Taking Grease #12
I've also had good luck removing the zerk and using a small drill bit to clean out the passage. Pump some grease through the zerk while it is off to clear it.
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56436)
2021 Unverferth...
2024 Schulte 5026 Batwing Rotary Cutter (A56435)
2024 Schulte 5026...
2015 Chevy Cruze Sedan (A56859)
2015 Chevy Cruze...
Mini Skid-Steer Forks (New/Unused) (A59225)
Mini Skid-Steer...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
