Grease Couplers for FEL
   / Grease Couplers for FEL #31
Thank you very much!
If it makes any difference now (a month later) I had the same issue with my LS MT125 loader and backhoe. I tried 5 different quick couplers and none would fit on the zerks in the recessed pins, especially on my backhoe. I finally stumbled onto the MacNaught KY Plus that someone else recommended and it works great. I highly recommend it!
   / Grease Couplers for FEL #32
Here is a link to the Macnaught KYPLUS grease coupler that many folks have been recommending in this thread
but I am wondering about this warning ?
IMPORTANT – DO NOT ATTEMPT TO BLEED GREASE GUN WITH KYPLUS COUPLER INSTALLED. REMOVE COUPLER PRIOR TO BLEEDING.
   / Grease Couplers for FEL #33
Looks like the KYPLUS is only 0.578" in diameter, vs the 0.62" of my unbranded unit. Looks like a winner.
   / Grease Couplers for FEL #34
I found 2 or 3 by searching Amazon. I ordered a XL Lock and Lube for $49. I think I will return it. I purchased a different one. I looks pretty good ...the tip is only .531" and it's not overly long...and it comes with a device for cleaning out the fitting and the recess. Something I hadn't thought about till I read a few of the posts here. It's called a Shall grease gun coupler. $19 ...the cleaning device is hard plastic but the coupler itself is all metal...just coated the same color. Has good reviews on Amazon.
1980 Gleaner F2 with heads (A55315)
1980 Gleaner F2...
2006 Caterpillar 315C L Hydraulic Excavator (A56857)
2006 Caterpillar...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2005 Toyota Highlander SUV (A56859)
2005 Toyota...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
