grease boot repair
/ grease boot repair #1
bamatoolmaker
alabama
kubota 3130
Is there a way to repair a torn grease boot?The tear is only an inch or so long and there must be a solution other than boot replacement or duct tape.
/ grease boot repair #2
It's a pain, but the only reliable repair is to replace the boot, or be prepared to grease it frequently.
The pain part is the disassembly required to R&R the boot. Just consider the cost of replacing the component you're greasing if it galls.
/ grease boot repair #3
What kind of grease boot? CV axle boot?
I've seen a redneck fix using fishing line and a curved 'leather' needle.. Worked fine.. looked.. well.. redneck-y
Soundguy
/ grease boot repair #4
I slipped & stuck a screwdriver through a good CV boot once. After the bout of swearing, I cleaned it thoroughly with brake cleaner, roughed up the boot around the tear & stuck a piece of inner tube over it using contact adhesive. Car passed our MOT test for the next three years!:)
Soundguy
This boot is on a tie rod.Your redneck fix would be harder for me than replacing the rubber.Thanks
/ grease boot repair #6
I have repaired the rubber boots on joysticks with liquid rubber. The kind that you use to make rubber grips on tools such as pliers and I have also use the kind used to cover electrical connections. I have seen them hold up for up to 4 years out in the weather all the time. I don't know how it would hold up on a tie rod. If you try it just make sure that the boot is cleaned real well.
/ grease boot repair #7
So have I, but getting a boot that's been used for grease glued is going to be challenging.
Might work temporarily though...
/ grease boot repair #8
Had you actually specified what the grease boot was that was torn.. we might have given you some taylored advice.
For instance.. on a tie rod.. my prefered mehod of fixing a torn boot is replacement of the rubber.. etc.. it's a no brainer really..
soundguy
/ grease boot repair #10
Soundguy,
I just want to let you know that "redneck-y" is my new favorite word.:D
Daryle.
/ grease boot repair #11
I work late hours and am constanly making up new words and grammar rules!
Soundguy
3146 (A63117)
3146 (A63117)
CAT R550/D11R Ripper Teeth (8) (A68134)
CAT R550/D11R...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
JOHN DEERE 4052M TRACTOR (A65057)
JOHN DEERE 4052M...
2013 CHEVROLET TAHOE (A66091)
2013 CHEVROLET...
Unused 2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
Unused 2023...
