Gravity Farm Diesel Tank, is it worth getting one.
   / Gravity Farm Diesel Tank, is it worth getting one. #31
Just get a 90 gal transfer tank with a 12v or hand pump. Put it on a wood frame so you can lift it with forks and put it in a trailer/truck. Take that to town and fill as needed. Get aluminum...it wont rust.
   / Gravity Farm Diesel Tank, is it worth getting one. #32
my last 100 gallon tank with a 12v pump cost me $300.00 used. was too much for what I would do in a year so went to a 50 gallon tank
   / Gravity Farm Diesel Tank, is it worth getting one. #33
This^
I bought a 105 gallon L shaped tank with 12v pump at an auction for $200.
CT
   / Gravity Farm Diesel Tank, is it worth getting one. #34
Ok, that is good to know. So lets look at the diesel use, on the L3301 I use about 3 gallons per day, on about 2 days a week, so lets say over 300 gallons a year, and just barely over 200 hours a year. So that seems to just reach the minimum...
wow! thats 1 1/2 gallon a hour. must be a good size tractor. my tractor and mini x both use about a gallon every 2-3hrs
a 100 gallon tank would have to be filled 3 times a year. easy to do in a pickup. or a 300 gallon tank on skids could be put on a trailer to fill
   / Gravity Farm Diesel Tank, is it worth getting one. #35
Must be a very small tractor and a very small mini-x ;)
   / Gravity Farm Diesel Tank, is it worth getting one. #36
I got tired of hauling cans so got a 100 gallon tank, mounted it in a 5 x 8 utility trailer I rarely used, and went with a 12v electric pump. When I did that, I was using about 300 gallons or 3 fills yearly. Then I went crazy helping farmers and started my own. I put a second 100 gallon tank in the trailer. Last year I sometimes burned through over 300 gallons weekly. Very handy as sometimes my equipment might be as far as 15 miles from home. I’m glad I went the portable route no matter how much or little I use.
   / Gravity Farm Diesel Tank, is it worth getting one. #37
Most diesel tractor engines have a fuel efficiency between about 14 and 17 HP-hrs/gallon at full load, less than that at partial load. 1 1/2 gallons/hour means his tractor has a maximum average load of 21-25 HP.
If you are using 1/2 to 1/3 gallon/hour, that would mean your average load would be no more than about 5-8 HP and that you probably are running engines of less than 30-35 HP in those pieces of equipment, else simply idling would use more fuel than that.
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
