Gravely Mower Won't Or Starts Too Soon
   / Gravely Mower Won't Or Starts Too Soon #1
HuntingKy
Sonora, KY
New Holland TC33D
I have an odd problem with my Gravely mower. It stopped turning over and although I was reading 12v at the solenoid, it still wouldn't start. After replacing the key switch and the starter solenoid, I finally found a loose pin in the wire loom running up to the engine. It appears to be ground cable with a loop back. If I leave this pin disconnected I can use a remote starter switch to jumper the solenoid and get it going. HOWEVER....if I reconnect that wire, it starts and runs as soon as I turn the key off the stop position. I suspect a bad ground or short to ground some place, possibly in another component but haven't been able to find it. Has anyone seen the issue?
Bump: no ideas?
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
1268 (A50490)
1268 (A50490)
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A53473)
Hay Van FL-95 Bale...
2007 KONECRANE SMV25-1200B STRAIGHT MAST FORKLIFT (A51406)
2007 KONECRANE...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
