Gravely Mower Won't Or Starts Too Soon
   / Gravely Mower Won't Or Starts Too Soon #1
HuntingKy
Sonora, KY
New Holland TC33D
I have an odd problem with my Gravely mower. It stopped turning over and although I was reading 12v at the solenoid, it still wouldn't start. After replacing the key switch and the starter solenoid, I finally found a loose pin in the wire loom running up to the engine. It appears to be ground cable with a loop back. If I leave this pin disconnected I can use a remote starter switch to jumper the solenoid and get it going. HOWEVER....if I reconnect that wire, it starts and runs as soon as I turn the key off the stop position. I suspect a bad ground or short to ground some place, possibly in another component but haven't been able to find it. Has anyone seen the issue?
Bump: no ideas?
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
Makinex Power Lifter (A52377)
Makinex Power...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
2014 SHOP BUILT  DISCHARGE MANIFOLD (A53843)
2014 SHOP BUILT...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
