Gravel Road Maintenance, Which Implement
/ Gravel Road Maintenance, Which Implement #1
KEROSENEDRVR
N. California
DK35
I've got about 3 miles of gravel driveway to maintain. I've got a bit of washboarding and a few rougher areas to work over. I've got a DK35 with a BB. I'm wondering what the concensus is on using the BB for this vs using something a bit more specialized such as a landplane, a rake or other attachment.
I'm looking for suggestions on what I should use and what would be size compatible for my machine?
/ Gravel Road Maintenance, Which Implement #2
Wow, 3 miles? /forums/images/graemlins/shocked.gif With a drive that long you may want to look into a DuraGrader or something similar. Check out this post.
I thought mine was long at 1500 ft. /forums/images/graemlins/crazy.gif
/ Gravel Road Maintenance, Which Implement #3
I don't think a backblade has enough weight to do a job on washboard roads. I'd go with a boxblade and finish with a york rake.
/ Gravel Road Maintenance, Which Implement #4
The heavy duty York rake with scarifiers and would be my first choice. The heavy duty rakes are heavy enough to be very effective and the scarifiers are great when washboard or pot holes need to be dug out.
A friend of mine has one that I have used and it sure did wonders on the drive and the scarifiers didi a good job of removing roots from an area of woods that was be turned into field.
This rake also had a metal panel that dropped down in from of the tines to move material like a rear blade would. The town highway department where I live uses a York rake on all their dirt roads to keep them in shape.
Randy
/ Gravel Road Maintenance, Which Implement #5
I've just had my CK30HST since this June and am new at all this. I have a 1/3mi driveway, steep, dirt/big rocks 6"/some old gravel.
I got a KK "professional" bb with tilt and I have been using it/learning the past few months, making ditches, making a crown, routing water flow as I see it change after rains.
I can't see how I could do that with a box blade or a rake. Maybe when I get it all finished with a bit of new gravel, after a while a rake would be good.
Mike
/ Gravel Road Maintenance, Which Implement #6
I grade our three miles of limerock road twice a month with a Bush Hog 84" box blade that weighs about 850 pounds, works excellent! /forums/images/graemlins/wink.gif
Sometimes I use a 72" box blade and it works good too, although it doesn't weigh or hold as much.
/ Gravel Road Maintenance, Which Implement #7
Add gauge wheels and weight to the back blade.
Egon
/ Gravel Road Maintenance, Which Implement #8
Do a search for Dura Grader. It looks like the ticket for maintaining a long gravel rd. I believe that if I had a longer driveway I'd buy one but I can't justify it with the drive I have. I'll just have to keep working with the box blade until I can achieve good results. /forums/images/graemlins/tongue.gif <font color="black"> </font>
How about attaching a 55 gallon drum filled with water to the BB. If I used rachet type straps I think it would stay put...
I'm having a hard time finding a dura-grader dealer on the left coast....
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
FIFTH WHEEL PLATE (A64276)
FIFTH WHEEL PLATE...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
2022 John Deere 5055E (A60462)
2022 John Deere...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
2006 Peterbilt C15 (A64127)
2006 Peterbilt C15...
