Gravel Road Dust Control
   / Gravel Road Dust Control
So this might be a new plan.
55 gal plastic barrel with top removed.
A fitting and valve installed hooked to a piece of pic hose tee'd into a 6' piece of pic pipe with drip holes and capped ends.
Mix the solution in the drum which is strapped into my fel.
Open the valve and drive down the road.
Profit!
   / Gravel Road Dust Control #12
Profit!
I like that.
   / Gravel Road Dust Control #13
Profit!
Go for it. Sounds perfectly doable to me!
   / Gravel Road Dust Control #14
We've used discarded/used cooking oil on short sections of gravel road. It eliminated dust completely for several months and we found it bonded the dirt real well for a better base.
Hey, use bacon grease. Smells good too!
   / Gravel Road Dust Control #16
All this sounds interesting ...
I've got about 300 ft of dirt/gravel road in front of my house where I would like to control the dust.
Am I correct in assuming the calcium chloride is basically rock salt, or ice melt? How much would need to be dissolved per gallon for effective control, and how many square feet per gallon would this treat?
Thanks
   / Gravel Road Dust Control #17
When I worked in the wine industry in Mendocino County, California, we had a Masonite particle board plant nearby. They gave us, free, a liquid waste product that smelled like molasses, which we spread for dust control. It took several layers, applied from a tank truck by gravity flow, before it was really thick but held nicely for about a year before it required a maintenance coat.
Check for similar products near you.
   / Gravel Road Dust Control #18
VATICAN CITY?!!
I am hugely impressed.
Are you trying to lay down marble dust? I am surprised you do not have a bi-directional Italian tractor for what must be tight quarters.
   / Gravel Road Dust Control #19
VATICAN CITY?!!
LOL ... What? You think we aren't plagued by dirt roads here in the Vatican? Every time that blasted Pope Mobile goes by, the clouds of dust are almost unbearable.
   / Gravel Road Dust Control #20
Profit!
I've spread Calcium Chloride on my dirt drive before and it does work well for keeping the dust down. I usually have mine sprayed professionally every other year or so because they use some type of compound that once soaked in almost creates a type of chipped asphalt surface that is much more durable to plowing.
Anyways back to the CaCl. They say the general recommendation is to use 3# of salt for every gallon of water. While the stuff does dissolve quite well it does take some work. I had issues with the stuff caking together. After mixing up about 5 gallons and not particularly happy at my progress I gave up on that venture.
I found my best results were to use a drop spreader instead of a broadcast since it allowed me to lay a heavier coat more evenly across the drive especially on the edges where most of the dust was without getting a bunch of salt on the lawn and killing the grass. I waited for a day that was going to just have a light/moderate rain for the better part of the day and spread it out. It worked quite well. I ended up using 5 bags of CaCl on a about a 150 yard drive.
I looked at that professional dust control products but the price and more so the cost of getting it shipped did not make it economical for me to go that route.
2022 Kubota Z422-54 Zero Turn Mower (A56436)
2022 Kubota...
2012 Jeep Grand Cherokee Multipurpose Vehicle (MPV), VIN # 1C4RJFAT3CC353156 (A57453)
2012 Jeep Grand...
Unused IRTPL 10,000lb Two Post Car Lift (A55272)
Unused IRTPL...
2013 BMW X5 AWD SUV (A56859)
2013 BMW X5 AWD...
2017 Ram 5500 Service Truck, VIN # 3C7WRMBJ9HG711025 (A57453)
2017 Ram 5500...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
