Gravel driveway, front bucket
   / Gravel driveway, front bucket #1
Borthwick
Fredericksburg
Kubota BX1860
I just read through the other thread in the snow removal sub which seems to focus on plow blades. I have a Kubota LA-203 bucket I’m working with.
I gather that ABS is the material to go with for a gravel driveway. I’m going to need a little help figuring out how to affix it to the bucket’s blade.
Give me your best ideas please.
   / Gravel driveway, front bucket #2
I think the best solution for a bucket on gravel is the use of bolt on skids. I have (2) Edge Tamers from R2 manufacturing that are perfect in gravel or grass.
   / Gravel driveway, front bucket #4
I ran a Ford 1210 with a 5' rear blade only (didn't have a loader) for a few years while the driveway was still gravel. It worked OK, but the blade often needed to be turned "backwards" to avoid wrecking the gravel. For the next 10 years it was a B7500 with an LA302 and a rear blade. This was after blacktop and that made it a whole lot nicer.
Occasionally we'd get a deep snow when the loader was handy, but most of the time the rear blade, angled to one side, worked just fine while driving forward.
   / Gravel driveway, front bucket #5
A back blade works a ton better than a front loader bucket, for snow. Almost always flipped around, backwards.
   / Gravel driveway, front bucket #7
Before my gravel driveway gets frozen I'm doing more snow grooming than snow removal. I dont even want to see gravel until spring thaw. I also dont rake piles of gravel in the spring because theres no gravel moved.
Granted the last few years I moved snow about 2x a year. Flat windy driveway. Amazon still seams to get stuck in.
   / Gravel driveway, front bucket #8
Same here. First couple storms I'll just leave there so as to build up a base. Until that gets frozen solid I'll raise the lip of the bucket an inch or so to keep from it digging in.
Maybe you're a lot more flexible than I am. Can't see myself clearing the driveway backwards.
   / Gravel driveway, front bucket #9
I snow blow a gravel driveway. We do the same. Get a layer of hard pack down first. Then blow off of that. I never pick up a single rock
  • Good Post
Reactions: JJT
   / Gravel driveway, front bucket #10
My driveway is sand and gravel and while I have Edge Tamers, I still just end up using the bucket as is. Just lay flat, curl the lip up about a 1/4" to make sure, place in Float, and push the hole length. The bucket fills up and becomes a plow. Haven't dug a hole yet.
3PT PTO POST HOLE DIGGER (A52708)
3PT PTO POST HOLE...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2026 Quality Steel Dump Trailer (A56858)
2026 Quality Steel...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
