Grasshopper Peruzzo Flail Mower Verticut Verticutter Dethatcher
   / Grasshopper Peruzzo Flail Mower Verticut Verticutter Dethatcher #1
Buxus
Maryland
Kubota M7060
Has anyone used one of these? Looks like it could be used for seeding and overseeding lawns. Basically a 60 inch flail mower that has the option of vertical blades that dethatch and cut the ground. Would combine the maneuverability of a zero turn with the smaller size of a slit seeder. Then just go over the area with a seed spreader. I already have the Grasshopper 930D mower. Looks like no way to get a slit seeder or aerator for less than $3k, and although this is more, it might be much easier if it works. Looks like it would work better for seeding than the Aerovator. Thoughts?
Front Flail Mower for Grasshopper Tractors -- Iowa Farm Equipment
   / Grasshopper Peruzzo Flail Mower Verticut Verticutter Dethatcher #2
I would seriously want to see exactly what the dethatcher did to the ground before purchase. The idea sounds great - the actual execution may be something totally different. I wonder - with the dethatcher blades - can the unit be lowered sufficiently to cut the ground as you would need for seeding???
2008 Freightliner Allegro Bay Class A Motorhome (A59231)
2008 Freightliner...
Towable Centrifugal Water Pump (A59228)
Towable...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
(INOP) MASSEY FERGUSON 1552 TRACTOR (A59823)
(INOP) MASSEY...
