Grasshopper 725, runs 20-30 min then dies
   / Grasshopper 725, runs 20-30 min then dies
Vent clogged in the carb? It needs atmospheric pressure on the bowl.
I don’t believe it’s fuel related. As spark disappears after warm or hot
   / Grasshopper 725, runs 20-30 min then dies #32
A common problem with tar-packed coils is they warm up and internally short much more frequently than oil-packed ignition coils (wow, now you know I'm old school if I know that, smile).
That said, this thing doesn't have a pickup coil or electronic ignition, does it? They too can work fine when room temperature but then have an open when hot and fail.
I tested the coil with meter both cold and hot and had same readings. Coil was actually cold to touch when it shut down.
   / Grasshopper 725, runs 20-30 min then dies #34
Is there a "low oil" shutdown on this?
   / Grasshopper 725, runs 20-30 min then dies #36
You should look. If the sensor fails, it could/does cut off the ignition.
I don’t see an oil sensor on the wiring diagram. Only an oil light.
   / Grasshopper 725, runs 20-30 min then dies #38
If it has a warning light, there has to be a sensor/switch. Find it on the motor and unplug (or maybe "short it" if it's got two wires). This will eliminate that possibility...
Well I checked all grounds, switches, relays and safety’s. All check out. I replaced the plugs and the distributor and seems to run great again. We shall see. Thanks
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A55745)
2004 FREIGHTLINER...
1997 Chevrolet C3500 Auto Crane Service Truck (A55852)
1997 Chevrolet...
2024 John Deere 317G Track Loader (A53485)
2024 John Deere...
1839 (A51248)
1839 (A51248)
