Grasshopper 725, runs 20-30 min then dies
   / Grasshopper 725, runs 20-30 min then dies
Vent clogged in the carb? It needs atmospheric pressure on the bowl.
I don’t believe it’s fuel related. As spark disappears after warm or hot
   / Grasshopper 725, runs 20-30 min then dies #32
A common problem with tar-packed coils is they warm up and internally short much more frequently than oil-packed ignition coils (wow, now you know I'm old school if I know that, smile).
That said, this thing doesn't have a pickup coil or electronic ignition, does it? They too can work fine when room temperature but then have an open when hot and fail.
I tested the coil with meter both cold and hot and had same readings. Coil was actually cold to touch when it shut down.
   / Grasshopper 725, runs 20-30 min then dies #34
Is there a "low oil" shutdown on this?
   / Grasshopper 725, runs 20-30 min then dies #36
You should look. If the sensor fails, it could/does cut off the ignition.
I don’t see an oil sensor on the wiring diagram. Only an oil light.
   / Grasshopper 725, runs 20-30 min then dies #38
If it has a warning light, there has to be a sensor/switch. Find it on the motor and unplug (or maybe "short it" if it's got two wires). This will eliminate that possibility...
Well I checked all grounds, switches, relays and safety’s. All check out. I replaced the plugs and the distributor and seems to run great again. We shall see. Thanks
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
UNKNOWN  UTILITY TRAILER (A55745)
UNKNOWN UTILITY...
2012 PETERBILT 388 DAYCAB (A55745)
2012 PETERBILT 388...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
