Grasshopper 725, runs 20-30 min then dies
   / Grasshopper 725, runs 20-30 min then dies
   / Grasshopper 725, runs 20-30 min then dies #13
Then the little 'do not remove' black box is shot and so is the rotor. Looks terrible, probably the cap is shot as well. Time to buy a replacement kit.
I cleaned it up a bit with some sandpaper. How do I go about finding out what Kubota motor I have to get a replacement? Everything I see and Google doesn’t come up with a Kubota motor.
   / Grasshopper 725, runs 20-30 min then dies #15
Call your local Kubota dealer and give him the engine serial number. He can get what you need. I would never buy any ignition related parts from Amascon simply because the quality won't be good.
The engine number is usually stamped on the head on the right or left hand side towards the front, below the valve cover. It begs for a bath as well, thing is filthy.
Thanks.
Yes i don’t disagree! If it wasn’t a front mount I would snatch it from my buddy!
   / Grasshopper 725, runs 20-30 min then dies #17
I own a Kubota Front mount diesel mower and so does a couple other posters on here, but again, mine is diesel not gas. Tank holds 15 gallons of diesel which is good for an entire season of mowing.
Is this electronic ignition or older points, condenser and coil system?
Kubota WG600 motor. It has a distributor, but I dont believe it has points.
   / Grasshopper 725, runs 20-30 min then dies #20
Here is a Grasshopper dealer I have bought parts from online and they have served me well!
I bought used 721D (Diesel) hopper back in 2003 and we are using it regularly.
Front deck zero turn mower is unbeatable when mowing around fruit trees.
The Mower Shop
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55314)
2020 Massey...
2000 Chevrolet C2500 Ext. Cab Pickup Truck (A55852)
2000 Chevrolet...
24ft T/A Flatbed Equipment Trailer (A55788)
24ft T/A Flatbed...
2015 Volkswagen Jetta Sedan (A53424)
2015 Volkswagen...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
