Grasshopper 725, runs 20-30 min then dies
   / Grasshopper 725, runs 20-30 min then dies #1
jorswift
Upland, IN
JD955, MF1528, JD2240, JD 4300, Ford Jubilee
Grasshopper 725 runs great for about 20-30 minutes then just dies. It then has to sit until it cools t o restart. Had a new coil put it and still continues. During the time it sits it does not have spark. Any ideas?
   / Grasshopper 725, runs 20-30 min then dies #2
Which engine does it have?
   / Grasshopper 725, runs 20-30 min then dies #4
Is this electronic ignition or older points, condenser and coil system?
I believe it’s a Kubota
Here are a few pics I could get today
   / Grasshopper 725, runs 20-30 min then dies #7
Clogged fuel filters will exhibit that symptom.
   / Grasshopper 725, runs 20-30 min then dies #8
Kubby 3 cylinder gasser... I'd say clogged fuel filter or bad condenser. Could be a gunked carb from bad e-gas as well.
Fogged fuel filter would? It doesn’t spark after it shuts down.
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
72'' power rake (A53421)
72'' power rake...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A55745)
2005 V.E...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
