Grasshopper 725, runs 20-30 min then dies
   / Grasshopper 725, runs 20-30 min then dies #1
jorswift
Upland, IN
JD955, MF1528, JD2240, JD 4300, Ford Jubilee
Grasshopper 725 runs great for about 20-30 minutes then just dies. It then has to sit until it cools t o restart. Had a new coil put it and still continues. During the time it sits it does not have spark. Any ideas?
   / Grasshopper 725, runs 20-30 min then dies #2
Which engine does it have?
   / Grasshopper 725, runs 20-30 min then dies #4
Is this electronic ignition or older points, condenser and coil system?
I believe it’s a Kubota
Here are a few pics I could get today
   / Grasshopper 725, runs 20-30 min then dies #7
Clogged fuel filters will exhibit that symptom.
   / Grasshopper 725, runs 20-30 min then dies #8
Kubby 3 cylinder gasser... I'd say clogged fuel filter or bad condenser. Could be a gunked carb from bad e-gas as well.
Fogged fuel filter would? It doesn’t spark after it shuts down.
2007 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W97X154872 (A54865)
2007 Ford Crown...
New/Unused Pallet Forks (A54865)
New/Unused Pallet...
BELSHE DT-235 (A55745)
2013 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2013 Ford F-550...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55302)
BOSS MT 660 Fuel...
UNUSED HYD AUGER (A52706)
UNUSED HYD AUGER...
