Mowing Grass removing seal in transmission
   / Grass removing seal in transmission #11
This has come up before in this forum...the issue then was the roll pin in the front driveshaft on B-series protrudes on either side of the shaft and hooks grass, wrapping around the shaft. One solution proposed was to cut off the protruding ends of the roll pin. I planned to do that, but I found it to be too confined to get at the pin to cut it. I like gghb's solution - stretch a piece of belting under the tractor.
That explains how the grass gets caught up on the front drive line . Thanks for your input as I will watch out for that .
   / Grass removing seal in transmission #12
I have never heard that one either . Did you keep it in 4wd while mowing all the time ?
Unless there are locking hubs or some other disconnect, the shaft will always turn when the tractor is moving.
David Kb7uns
   / Grass removing seal in transmission #13
David Kb7uns
Thanks , I didn't realize that .
Cushman Utility Vehicle Golf Cart (A55853)
Cushman Utility...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
(4) 8 LUG 16 1/2 WHEELS (A57192)
(4) 8 LUG 16 1/2...
LaneShark LS3 (A56469)
(2) 42" HANG ON FORKS (A54757)
(2) 42" HANG ON...
