Mowing Grass removing seal in transmission
   / Grass removing seal in transmission #11
This has come up before in this forum...the issue then was the roll pin in the front driveshaft on B-series protrudes on either side of the shaft and hooks grass, wrapping around the shaft. One solution proposed was to cut off the protruding ends of the roll pin. I planned to do that, but I found it to be too confined to get at the pin to cut it. I like gghb's solution - stretch a piece of belting under the tractor.
That explains how the grass gets caught up on the front drive line . Thanks for your input as I will watch out for that .
   / Grass removing seal in transmission #12
I have never heard that one either . Did you keep it in 4wd while mowing all the time ?
Unless there are locking hubs or some other disconnect, the shaft will always turn when the tractor is moving.
David Kb7uns
   / Grass removing seal in transmission #13
David Kb7uns
Thanks , I didn't realize that .
LINCOLN ELECTRIC POWER WAVE 455M WELDER (A57192)
LINCOLN ELECTRIC...
CAT PS-150C (A53317)
UNUSED RAYTREE RMT 48 48" HYD TRENCHER (A57193)
UNUSED RAYTREE RMT...
2014 Nissan Rogue Select SUV (A55853)
2014 Nissan Rogue...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
KUBOTA KX057-5 EXCAVATOR (A52707)
KUBOTA KX057-5...
