Grappling fun - A Picture Thread....
   / Grappling fun - A Picture Thread.... #1,221
Trimmed the trees and tore up some brush. What a difference a grapple makes.
   / Grappling fun - A Picture Thread.... #1,223
I've never heard of a rear mounted "root rake". I've tried to use my landscape rake like you did but it is mostly a fruitless waste of time to try collecting sticks and the like that way. The debris just clogs up the rake and the rake jumps over it or digs up the turf. Big mess.
This is what comes to mind for a CUT rear attachment for getting roots out of the ground.
Bruce
   / Grappling fun - A Picture Thread.... #1,224
Bruce
Interesting. Not a very common implement. I guess I would just use my box blade with tines extended and without the main blade in contact with the soil to do the same thing. That or just use a root grapple. I am having a hard time envisioning a large area with surface roots that need ripping out. I certainly have fields where I know there are briar roots etc under the turf but I deal with them by mowing regularly so they eventually die off. Trouble with trying to rip out the roots is that if you leave just a fragment of root behind some plants will just regrow anyways.
   / Grappling fun - A Picture Thread.... #1,225
The difference between those and a box blade is the scarifiers can go much deeper, if your tractor can pull it.
I like the one with the piggyback rake, if you can use either one by adjusting the top link instead of having to change implements.
Bruce
   / Grappling fun - A Picture Thread.... #1,226
   / Grappling fun - A Picture Thread.... #1,227
I had a thread about this a couple weeks ago.
The largest load I've picked up with tractor and grapple, a large dead hickory trunk:
IMG_20170320_160712928 (Large).jpgIMG_20170320_160707595_HDR (Large).jpgIMG_20170320_160738961 (Large).jpgIMG_20170320_160730556 (Large).jpgIMG_20170320_160800392 (Large).jpg
   / Grappling fun - A Picture Thread.... #1,228
Nice. Are you just using a box blade as ballast or are your tires filled? What grapple is that? Looks like a good match.
   / Grappling fun - A Picture Thread.... #1,229
IT,
Yes the BB is my go-to ballast. It weighs 675 lbs, has 410 lb concrete, steel and lead weight block on the end that also holds my Ratchet Rake, my tires are filled and I have 500 lbs of concrete, steel and lead wheel weights. That trunk came very close to lifting my rear tires!
The 48" grapple I got from Skid Steer Attachment Depot, a local dealer in Huntsville AL. The only problem I have with it is the male end of the FF connectors on the tractor side always has to be dissembled to connect the grapple. What a PIA.
   / Grappling fun - A Picture Thread.... #1,230
Is the lid up or down when disconnected?
   / Grappling fun - A Picture Thread.... #1,231
IT,
Just whack the tip with a wrench or hammer to let out pressurized oil. No need to disassemble.
   / Grappling fun - A Picture Thread.... #1,232
   / Grappling fun - A Picture Thread.... #1,233
Not so easy on a flat face connector.
True but I thought the flat faced connectors didn't have the pressure related connect problem. I've never used one but thought that was the main advantage. I guess not.
In that case then do what I do with recalcitrant female connectors: put a phillips screwdriver head or blunted nail into the middle and give that a whack.
   / Grappling fun - A Picture Thread.... #1,235
My Cat skid steer has flat couplers. I always fought with them until I found out how to release the pressure in the cab before unhooking the implement.
   / Grappling fun - A Picture Thread.... #1,236
Which was.........????
   / Grappling fun - A Picture Thread.... #1,237
Doesn't work.
BTW, by "disassembling" I meant I have to loosen the swivel behind the connector on the tractor side a few rotations, just enough to let the oil out when I connect.
   / Grappling fun - A Picture Thread.... #1,238
Doesn't work.
I've never used a flatfaced connector (is that what you have?). I can tell you though that the regular male Pioneer style connectors can easily be cleared of pressure by just whacking the tip. Least messy way is to throw a rag over the tip and then tap with a hammer. I often just grab the loose connector and whack it against the grapple.
   / Grappling fun - A Picture Thread.... #1,239
I will just go thru this and you can take if for what it is worth. I shut off the tractor. Then work the control valve back and forth going thru the neutral position several times. Then disconnect the connectors from the QC connectors on the torque tube of the loader. I have a male and a female Pioneer type, also called AG's 1/2 inch Quick connectors. I then immediately connect the male and female connectors together. Then immediately disconnect them and let the small amount of oil puke out. Then reconnect the connectors together for storage. By connecting and reconnecting the connectors together while they are hot and letting the oil puke out, this causes a deficit in the amount of oil in the lines. It isn't in the lines any more, it is on the ground. It cannot heat up in the sun and build any pressure.
End result, I never, ever, ever have any problem reconnecting the QC's to the tractor when the time comes. I don't have to hit the balls with anything, I just push them on. I know a lot of you fellas struggle with these connectors. I don't. Years ago I used to struggle with them too. I don't do that anymore.
You can take my advice for what it is worth or not.
   / Grappling fun - A Picture Thread.... #1,240
If I had the flat face connectors and they were both the same ***, I would build a short adaptor hose with two of the opposite *** on the hose. I would plug and unplug the couplers into the adaptor hose to allow oil to "puke" into the hose. Then leave it on the connectors to keep it clean. Drain the adaptor hose once in a while to remove the oil puked into the hose.
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
Hyster 60 6,000lb Diesel Forklift (A59228)
Hyster 60 6,000lb...
American G-Model Pump Jack (A56438)
American G-Model...
Towable T/A Flammable Liquid Transport Tank (A59228)
Towable T/A...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56438)
Michelin CARGOXBIB...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
