Buying Advice Grapples for GL5240
/ Grapples for GL5240 #1
ih364
Is there a preffered Kubota supplier for root grapples for the GL 5240?
/ Grapples for GL5240 #2
I am not sure about preferred Kubota supplier. The Kubota dealer near me sells 3 different brand grapples. There are several threads here about grapples. If you have not already done so, check them out for some ideas.
The reason I'm searching it that I have a good root grapple I bought from Grabce Mfg when I was rentng T-190 Bobcats, I feel at 1100 lbs I'm using a lot of my lift capacity on the weight of the grapple. At this point I use the grapple for picking up brush and cedar trees. Some cedars can be heavy so at that point I use a boom on the three point to drag.
/ Grapples for GL5240 #4
I am a big fan of wildcat attachments. I have a 60" that is heavy duty With two independent arms and double acting pistons. I believe that it weighs just around 650lbs. Can't beat the price. I purchased directly from them, and had a good experience.
With l4740 withe the 854 loader and have no problem lifting 2000 lbs. most of the time I am using it for fire wood and lift 2 or 3 16 foot 12 to 20" diameter logs.
Http://www.wildkatattachments.com/
/ Grapples for GL5240 #6
The "which grapple" debate is about as rich and entertaining as the "JD vs Kubota" debate. Lots of posts/threads here and elsewhere on this.
If you're going to uproot trees and dig out rocks, you want something that is stout enough to not fold up into a pretzel. Both Anbo and Bradco make really really heavy duty grapples with steel up to 1" thick. But they're heavy, so you lose more of your lift capacity and you get a more unsteady feeling carrying stuff around in your grapple.
If you're going to move brush piles and stuff you might want to go with a light duty grapple. Not only do they give you more net lift capacity but they are cheaper.
I think you'll also find the more expensive units are welded up from abrasion resistant steel plate (kind of like your loader and box scraper). Whether this is important or not depends on how you will use the grapple, but it does add considerably to the cost of the unit.
Finally, there have been some good arguments (mostly put forward cogently by IslandTractor) that a narrower grapple is preferable to a wider grapple. Obviously a narrower one is cheaper and lighter than a wider one, all things being equal.
Finally, there was one big grapple fabricator in North or south Carolina (can't remember which) that spawned a bunch of clones as employees set up shop on their own. So this leaves a lot of choices of manufacturers, who often make what appear to be identical units. And, of course, the Chinese are now involved making really cheap ones (but not necessarily bad ones).
HTH.
2022 EZ-GO ELITE...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
White 18' Disk (A66408)
White 18' Disk...
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
JOHN DEERE 606C - 6R30" CORN HEAD (A64277)
JOHN DEERE 606C -...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
