Loader Grapple!!!!
   / Grapple!!!! #21
Thanks ^^^^^^^.
   / Grapple!!!! #22
Not sure where I heard it but the rule of thumb on larger tractors is the weight of the loader attachment (so bucket and grapple) should be < 40% of your rated lift capacity. I would assume the same holds true for compact tractors. I believe typically rated lift capacity does not include the weight of the bucket as bucket sizes and options will vary by brand - that is why the lift capacity is usually advertised as being measured from a standard distance from the bucket pivot pin.
   / Grapple!!!! #23
I spent a WHOLE LOT of time reviewing my FEL weight lift charts before I bought my Land Pride grapple. A lot of time at the Kubota dealer - measuring pivot pin distance to center of the loads I would be working with.
jeepcj7 is spot on. The manufacturers had to come up with some, more or less, standard distances. OR at least, call them out when they specify load capacity.
   / Grapple!!!!
Sorry I have not responded to anyone was not getting notified. I found another grapple made by Worksaver. that only weighs 205lbs. Price I found was alittle less then $1400 Here is a link, Sub-Compact Tractor Mini Tine Grapple I am also looking for 3rd function ideas.
   / Grapple!!!! #25
If you haven't committed, I'll be glad to provide guidance. The worksaver has a single 1.5" bore cylinder. Wicked 55 features two, 2" bore cylinders and a true root rake design. When fully open, our lid bottoms out on the grapple frame, so you can rake loose material backwards without causing any damage. Ask worksaver if they advise such activity. Hint.. the answer is no. AR450 Steel and thick wall DOM tubing is the strongest, most premium combination of materials in the industry. Serrated Wicked tines rip and grip like none other. Greasable pivot points and cylinder pins. Almost 200 customer reviews, dozens of pics, testing video with our 60hp Kubota and several other customer videos can be found here Best Rated 55 Inch Wicked Root Rake Grapple from Everything Attachments I'll make the decision very easy for any compact tractor owner. If you want what's best to maximize your tractor's ability, Wicked is the only choice. Travis
More info coming soon! (A49346)
More info coming...
10' Feed Bunk (A50515)
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
UNUSED FUTURE VIBRATORY ROLLER (A51244)
UNUSED FUTURE...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
