Grapple will open, but will not close however, it works manually when depressing at the end of the spools
   / Grapple will open, but will not close however, it works manually when depressing at the end of the spools #11
Have you checked to see if you are getting 12 volts at the valve when the switch is pressed?
If you are and it still doesn't work check the resistance of the coils on the valve. They should be the same resistance. Why does a grapple need a circuit board?
I guess that they were thinking one day. You know, if we don't put a special module, they won't have to buy a special module from us. We've not been thinking, boys.
   / Grapple will open, but will not close however, it works manually when depressing at the end of the spools #12
Sadly I think there is some of that going on. Take something simple and make complicated or use "special" components to marry you to the OEM.
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A51039)
Texas Post Driver...
2016 CAT 289D SKIDSTEER (A50854)
2016 CAT 289D...
2014 TOYOTA 8FGCU25 FORKLIFT (A51222)
2014 TOYOTA...
2013 Chevrolet Malibu Sedan (A50324)
2013 Chevrolet...
