Grapple will open, but will not close however, it works manually when depressing at the end of the spools
   / Grapple will open, but will not close however, it works manually when depressing at the end of the spools #11
Have you checked to see if you are getting 12 volts at the valve when the switch is pressed?
If you are and it still doesn't work check the resistance of the coils on the valve. They should be the same resistance. Why does a grapple need a circuit board?
I guess that they were thinking one day. You know, if we don't put a special module, they won't have to buy a special module from us. We've not been thinking, boys.
   / Grapple will open, but will not close however, it works manually when depressing at the end of the spools #12
Sadly I think there is some of that going on. Take something simple and make complicated or use "special" components to marry you to the OEM.
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
2012 Chevrolet Traverse SUV (A50324)
2012 Chevrolet...
Super Material Lift MH1000 (A51039)
Super Material...
