Grapple width. Same as bucket or narrower?
   / Grapple width. Same as bucket or narrower? #31
I have a 72" grapple. It matches my 72" bucket. I don't understand how much more maneuverable a 60" grapple would be over a 72". To me it is a non issue. 12" narrower 36" out front of the bucket is not a big deal. If it is my tractor is too big to start with. Weight is more important in smaller CUT's with limited FEL lifting capacity. And as Rich pointed out it could be an issue in transportation. Get the grapple and be happy. I am. You will be too.
   / Grapple width. Same as bucket or narrower? #32
So back to the original question for a minute. Most prefer narrower than a 72?
My question is why do you need a 72" grapple... what do you plan on grappling? Where do you plan on using it, woods, open field, working farm? How much does the grapple weigh? If you're only using it to grapple a few trees, rocks, or brush would something smaller and lighter do the trick? Bigger isn't always better. I suppose if you have a large tractor or Skid steer and use it commercially I can understand getting the largest that fits... time is money. I personally wouldn't opt for anything much over 48", having a 35HP tractor wouldn't afford the power needed to dig roots, lift logs, or rocks. If you believe the 72 is what you need .... buy it.
I have a grapple ordered from EA. Talked to Travis about width. I ordered a 72" dual lid as that is the width of my loader. We talked about a 66" and I thought I want the same width as my loader. I think I made the right choice but not sure I made the right choice. I have never used one. Weight is not an issue. We are talking 3 inches on each side. I do not want to get into a debate of dual or single lid just wondering if you went narrower than your tractor. I will be hiring out doing storm cleanups. Thanks.
   / Grapple width. Same as bucket or narrower? #35
My grapple - Land Pride SGC1560 is 60" wide - my bucket is 72".
   / Grapple width. Same as bucket or narrower? #36
Maybe I should back off to a 66". I am only looking to do storm cleanups and not sure what I will run into. I am sure there will be an occasional run into the woods to clear them also.
If by "storm cleanup" you are also talking about debris from a home that has flooded out or construction debris, then a wider grapple bucket makes sense. A load of broken boards and trash is a different animal than picking up a pile of nicely intertwined brush.
   / Grapple width. Same as bucket or narrower? #37
You talked to Travis for an expert opinion and have ordered the grapple you chose. Now on the 4th page of comments and apparently everyone has their own preferences to suit their individual purposes.
So why are you repeatedly asking the same question? :rolleyes:
Just to irritate you. Is it working? Yes, Travis is very knowledgeable. Some on her are also. I do not consider you one of them.
   / Grapple width. Same as bucket or narrower? #40
According to my memory, you have already ordered your Grapple. Now you are wanting to debate width. A little late I'd say. I'm with Oldoak, you've wore this question out. :)
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2013 Chevy Silverado 2500 HD (A51039)
2013 Chevy...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A51039)
2014 Ford F550 4x4...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
