grapple trouble
   / grapple trouble #1
rpoe
Northwest Arkansas
searching
took delivery yesterday on a used L3940, had the dealership add a grapple and a diverter on the joystick. I think the grapple is an Enlow, the diverter is a WH Long. Yesterday it worked fine, but today it will only open about 12", as if I have set a lock on it and it just won't get any wider. It will close back down just fine, but not open much. The boom itself is working fine, I can raise, lower, and curl the grapple, just not open/close it very much.
Have I probably reset something or caused a problem? I hardly used it, just picked up a few small logs. Seems odd that it would work fine first day and then not work, unless I've done something dumb.
   / grapple trouble #2
You don't have a "problem" per say, you have just found the regenerative function of your FEL valve. Basically you need to push the joystick further to the right to get past he regen feature of the valve.
Read THIS for a great explanation.
   / grapple trouble #3
I have a Fasse diverter valve for an WR Long grapple on a L4310.
When the temperature dips below about 20 deg-F, the circuit need to warm up. In winter I typically have the bucket on and let the tractor warm up say 20 minutes, then it slowly allows curl operation. Becomes quicker after slow operation.
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2016 CATERPILLAR 311FLRR EXCAVATOR (A60429)
2016 CATERPILLAR...
2461 (A58376)
2461 (A58376)
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
