Loader Grapple slow to close
   / Grapple slow to close #1
ernram
Bastrop, Texas
John Deere 5085M
I have a JD 5085M with triple mid SCV option. Today at the end of the day, the grapple was slow to open, but it was fine closing.
It is definitely a hydraulic related. So it is either something up with the SCV or one of the grapple cylinders is end of life-ing.
Any suggestions on root causing which?
Thanks,
Ernie
   / Grapple slow to close #2
quick disconnects. undo them and then put them back together. it just one of them first things to try, that anyone can do. you more likely see it when you initially hook something up and nothing is happening. so ya redo the QD's. some times QD do not seat properly and allow hyd oil to flow through them correctly. maybe ya snagged a branch that hit them or some sort, who knows what.
just try unhooking them and re-hooking the QD's back together.
if not QD's, then your looking at more stuff that involves more to it. from pressure gauges to a volt meter / amp meter. to check stuff.
do you have 3 levers vs say a joystick and a button for the FEL?
does everything else work correctly? 3pt hitch? raising / lowering curl/un-curl work on the FEL?
   / Grapple slow to close #3
I agree start with connectors. Next swap the connectors (connect the hoses opposite) and see if the problem follows as in now slow to open instead of slow to close.
   / Grapple slow to close #4
There was a most excellent post from Steve aka Buckitcase just a few days ago about why the QDs give these problems.
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
2021 Ford Mustang Mach-E AWD SUV (A55853)
2021 Ford Mustang...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55853)
2023 Fat Truck...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2013 Cadillac SRX SUV (A53424)
2013 Cadillac SRX...
