Grapple Size ??
/ Grapple Size ?? #21
I thought an MX has a loader near the L39/L45/L47 capacity, i.e. about 1 ton Lift?
A light duty is great for logs and brush but playing with rocks is rough on grapples and I'd tend toward the 75Hp-600 lb wicked grapple if rock are a concern.
X2 :thumbsup:
/ Grapple Size ?? #22
Breakout force (loader lift at ground level) is 4200# at the pins and 3200# at the bucket edge.
Capacity at max height is 2500# at pins and 1850# at bucket edge.
Not sure what the TLB's are. But unless its poorly made, a 400-500# grapple is not gonna get hurt by the MX loader
/ Grapple Size ?? #23
If used on brush... Probably. IMO.
/ Grapple Size ?? #24
I've use mine on big rocks and slabs of concrete, moving junk, logs, ripping up roots, moving implements, etc. Just about everything you can imagine. Trying to push and pry against a rock or root, with everything she's got, I still stand by my comment. Ain't no mx-sized loader gonna hurt a well made 400-500# grapple. And IMO, an 800# grapple is a waste of money and lift capacity.
Now if I was shopping g for a grapple for my backhoe with 6000-7000# lift capacity with 18k pounds behind it...Then yea, that would justify the added cost and weight for a heavy grapple
/ Grapple Size ?? #25
LD1 is right, I have the same loader as the MX tractors and my WR Long 500lb grapple is more than strong enough for my loader. These loaders really aren't that powerful.
/ Grapple Size ?? #27
My grapple is well over 800lbs. Only ever used on my MX. I don't know what else to say.
/ Grapple Size ?? #28
Personal opinion is that I would rather tear up a grapple because it was lightweight rather than stress the loader frame with a heavier grapple. I'm pretty careful with my FEL so it's probably a mute point. I can always beef the grapple up if it needs it. It's back to personal preference. No absolute right or wrong answer.
/ Grapple Size ?? #29
Like Luke says - my grapple is the only one I've ever had. Works great with my M6040 and works with anything/everything I've got on my property. It will lift my heavy pine logs and raise the loaded rear tires even with my 800# LPGS on the 3-point. But only once - cut my big logs down to 10 foot chunks.
/ Grapple Size ?? #30
This is the OEM Loader Spec Graph. (1 Kg = 2.2 lbs.)
This Sunday we used the L39 to load a steer on the back of the butchers truck, hanging off a chain hung off the front of my snow plow. I was tilted on at most a 5% grade, but at full lift height that poor cow at only 1300-1400 lbs had me nervous swaying around. I've seen too many you tube videos of cranes toppling over.
So always try to carry the load as low as possible.
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
