Grapple hydraulic hose "Keepers"
   / Grapple hydraulic hose "Keepers" #11
Ta, James! Now I see what you've done.
My FEL 3rd Function jacks end at the R-hand arm as opposed to yours, which end in the middle. My 4in1 has the long hydraulic lines. So far, there's no interference but I'll keep the bungie-cord (also known here as an 'ockie-strap') solution in the back of my noggin for the future.
Very good. I thought of you today while I had the tractor out, and I had the phone in my pocket. :)
   / Grapple hydraulic hose "Keepers" #12
I used a spring for a screen door and put a stainless circle loop ( not the correct name ) but don't know what else its called? Works great for me. 20160403_195055.jpg
   / Grapple hydraulic hose "Keepers" #13
Lots of different ways..:)
   / Grapple hydraulic hose "Keepers" #16
And then slip a sleeve over them for further protection.
I'll soon to be embarking on ordering hydraulic bits for my grapple, and I've already got all my bits for my hydraulic top link. With regards to sleeve protectors, what's the general rule for where/when to use them? I'm thinking that anywhere where the hoses are out in the open (or otherwise prone to being snagged) should be sleeved. Some folks, I see, even sleeve hoses along their FEL.
   / Grapple hydraulic hose "Keepers" #17
I just remembered where I got my hose keeper I mounted on my grapple Tractor hose reroute kit While it says welded a bolt and washer does fine.
   / Grapple hydraulic hose "Keepers" #18
I use a couple large zip ties loosely tied but had a couple failed installs before I got the length vs. movement correct. I do like the bungee cord idea better.
Camera focus is not very good but you get the point: _EM51476.JPG
   / Grapple hydraulic hose "Keepers" #19
I used an old trampoline spring and some metal tent stakes on the cross tube. It has worked well for me.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A51572)
2003 Isuzu NPR-HD...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
