Grapple build
/ Grapple build #21
Nice job. Yeah it would be nice to have a close up of how you hooked up the controls for the hydraulics.I will have to make one for the fel and bh over the next year . Have too many things on my plate just now.
/ Grapple build
Here is a pic of the plumbing.
/ Grapple build #23
I thought your cylinder looked very large for your application.
If you have trouble strengthening your bucket enough you might consider a smaller diameter cylinder.
/ Grapple build
The cylinder is 1.5" dia. I'm going to weld a 2 x 2 x 1/4" piece of angle iron to the bucket along its whole length. If that doesn't work I was thinks of messing with the pressure relief setting.
/ Grapple build #25
2310, A suggestion, when you extend your piece of angle (great idea, by the way) try to find a way to mount it to the sides. A lot of people make a flange using flat steel, so that it bolts to the sides of the bucket. Just search "grapple" and you will see some of the examples.
You also hit on great topic, the relief valve. I would think on a grapple, if anyone has an adjustable relief, they would set it to relieve before the point where it is bending/stressing the bucket or hinge points.
This sounds like a very good idea. Unless you are intending on crushing cinder blocks, I would think most of us with smaller set-ups can protect against damage by by making this adjustments.
Sounds like you have the issue under control, good luck, let us know how it goes.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
1996 Lincoln Town Car Sedan (A59231)
1996 Lincoln Town...
2012 CATERPILLAR 316EL EXCAVATOR (A62129)
2012 CATERPILLAR...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
