Grapple Build, suggestions for bushings
   / Grapple Build, suggestions for bushings #21
They sell different size collars at TS, I would use them and weld them to the outside of material, add zerk and call it good.
Most collars are made of carbon steel like C45 (dont know the US equivalent) which is meant to be machined, not welded. The higher carbon content makes it prone to crack right beside the weld, in the Heat Affected Zone (HAZ) I was once asked my opinion about why these things cracked off the frames, in a company i just started working for. I asked them, look up the material, its most likely C45. And it was. Replaced by DOM tubing and no problems since.
   / Grapple Build, suggestions for bushings #22
good to know, thank you.
   / Grapple Build, suggestions for bushings #23
Yes, good information. Thanks for posting.
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58018)
2018 FREIGHTLINER...
2012 Ford F-250 (A55973)
2012 Ford F-250...
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A56435)
2023 Kubota...
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
