Grain drill or 3 point spreader
   / Grain drill or 3 point spreader #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
I've always used the grain drill for rye grass and wheat ... my neighbor told me to use his 3 point spreader says it will be faster and does as good a job.
Questions for those that have used the spreader ... I have the field disc'd and am ready ...
1.) Best to use a drag harrow after seeding?
2.) He doesn't have the manual ... what setting on the spreader for Rye Grass?
3.) What setting for wheat?
OR ... just use the good old JD Grain Drill?
Thanks ...
   / Grain drill or 3 point spreader #2
If you use the seeder/spreader, use a cultipacker to put the seed in. I always set the spreader at about 1/2 what I think it should be and usually wind up double covering. I seed with a broadcast seeder this way, just to ensure I don't run out of seed before I run out of field. Ken Sweet
   / Grain drill or 3 point spreader #3
The rye is going to run out much faster than wheat, probably 2 or 3x. My pendular spreader has rye and wheat in the manual, but I'm sure they are all different.
   / Grain drill or 3 point spreader #4
The grain drill may be easier to adjust and to keep coverage even.:D
Ya ... after sleeping on it I have decided to use the drill. Always has worked.
   / Grain drill or 3 point spreader #6
I've used both and find I waste a lot of seed with the 3-point pto hopper spreader. Much better control and even distribution with the grain drill seeder. I use the hopper for fertilizer and lime.
2011 Freightliner Cascadia 113 S/A Day Cab Truck Tractor (A59230)
2011 Freightliner...
2012 International Prostar (A56438)
2012 International...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
2004 JOHN DEERE 650H LGP CRAWLER DOZER (A60429)
2004 JOHN DEERE...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
