I have a Kubota B3200 with a bh76 and I would like to put a grading bucket on it. Is that possible? Has anyone one here done that and if so where did you find the grading bucket? Im thinking maybe a 30”?
I made a 30" edge that slipped on over the teeth and was secured by a chain welded on the back side that got hooked on a hook welded high on the bucket.
This was over 30 years ago and a little Woods 3pt backhoe on my first new tractor. Wish I still had that Yanmar 336D!
For what I had invested, it was hard to beat and much simpler and faster than swapping buckets.
I have several worn grader blades from the county. My BH bucket is 18", so I had my welder cut two pieces 18" long and drilled two holes in each. I just put them on the teeth and tighten the bolts. Works great for me.
I ideal though for 30" you would want it to swivel so it will follow the contour of the ground.
