Grading an agility field
/ Grading an agility field #1
mbgt2003
Kubota
I'm currently grading an agility field (80x120')
which is about 2 feet lower on one site.
I started moving dirt with the box blade but it is very messy to run over the accumulated dirt every time when I bring another box full of earth downhill.
Any suggestions on a more streamlined approach.
Thanks
MB /forums/images/graemlins/confused.gif
/ Grading an agility field #2
If you lift the blade very slowly as you drive, it will spread the dirt in flat sheets, and as you drive over with more loads it will help pack it - which is a good thing! Two feet of dirt dumped in uneven piles is going to settle out kinda lumpy.
What is an agility field?
--->Paul
/ Grading an agility field #3
Be patient you will get much better at this as you practice. I was having the same problem for a while but practice helped a lot. Now I use my position control to feather it out much more evenly.
Thanks for the encouragement.
An agility field is for dog agility trials.
Running over hurdles, jumping, tunnels etc.
MB
/ Grading an agility field #5
Have a FEL? Maybe move the dirt first and then level. Have a dump trailer or truck or some way to move the dirt?
Wouldn't a scraper blade pull more dirt than a box blade? Then use the box blade to level it up.
/ Grading an agility field #6
Well, my 250'x200' Schutzhund field isn't quite level, but it is smooth. Our jumps are limited to a 1 meter brush hurdle and a 1.8 meter A frame with 1.9 meter sides. But we also have 90 pound dogs making contact with the bad guy at about 30 mph.
I cut down several hundred small trees in early spring, and had a dozer push all the stumps for me. I graded and raked my field in July, when it was as dry as possible, and seeded just before a gentle multi-day rainstorm that the weather-guessers got right.
If you really feel it has to be perfectly level then I would talk to somebody with a dozer. I would be concerned that if you don't plan drainage up front then it will be soggy a lot of the time. Of course, this depends on your local soils and climate.
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
2014 Bobcat E63 (A64126)
2014 Bobcat E63...
Massey Ferguson 8200 Flex Grain Platform (A66285)
Massey Ferguson...
2022 EZ-GO ELITE...
