Grader, scraper implements ?
/ Grader, scraper implements ? #1
tandttravis
Bronze Member
Wasatch Mountains, Utah
Kubota B-26
What type of grader implement would you guys reccomend? I need to set finish grade around my house and cut drainage swales and such. I was thinking of a scraper vs a box scraper because it has more side angle adjustment, but I'm looking for a bit of input. I have a B-26
/ Grader, scraper implements ? #2
Box blade with scarifers over a regular rear blade. Especially for making swales. Rear blades don't dig well unless very heavy, which means your B-26 wont have a chance. (Unless your soil is very soft.) In my area, most final grading on construction sites are done with box blade. With my own house I used a box blade. Superior choice.
/ Grader, scraper implements ? #3
I've got both an 8ft blade and a 6ft box blade, and the box blade is far superior for moving material around. However, when it comes to a final, flat grade, the larger straight blade does a better job.
So, for your application, I think a box blade is just the ticket. You can drag material along, and then grade it out just where you need it. A straight blade means you're almost always losing material out the side, one way or the other (or both!).
- Jay
/ Grader, scraper implements ? #4
With the infinite position control that the B-26 has, I also recommend a box blade. You can pull, push, or relocate the material; but get one wide enough to cover your tracks, probably a 60" for your tractor?
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A64557)
2007 30ft. Regal...
2014 VOLVO A25G OFF ROAD DUMP TRUCK (A65053)
2014 VOLVO A25G...
ATS Power ATS-RT12R Mini Excavator (A66408)
ATS Power...
2013 Nissan Pathfinder SUV (A64557)
2013 Nissan...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
2017 Hyundai Santa Fe AWD SUV (A61574)
2017 Hyundai Santa...
