grader blade size?
/ grader blade size? #21
I used it for the first time today, fixing the county road that goes to my farm. I have a lot to learn as far as technique and efficiency goes, but I am really happy with it. 8ft is actually a good size. For what I was doing, I could angle it sharply and not need any offset. For most of my work, it’ll be angled the full extent. Tractor felt plenty heavy enough.
Pictures
/ grader blade size? #22
I have a 55hp TYM t574, about 65" wide. We have probably a couple of miles of dirt roads on our property in east texas, red clay soil. With heavy rains the roads get a lot of runoff washouts. Ive been smoothing them with a box blade, but think a grader blade that i could cut a runoff ditch on the sides and try to keep crowned a bit would be a better option. Should i look at a 7' with offset ability or an 8'? Or would a regular 7' be wide enough when angled?
Can you use the 3-pt leveling feature to raise one end of your box-blade? If you can, you can make a pass on each side and it will build the crown, just don't try to make it all at once (shallow cuts), make several passes to "sneak up" on the crown.
I do that with my crushed stone driveway because it's easier to make a mistake doing it all at once.
Yes. I have tried that, but i think...and maybe i am wrong....that having an angled blade when building a crown will move dirt more toward the middle. Or maybe im not using the box at a lifted angle correctly?
/ grader blade size? #24
My landplane has angled blades, and when using a regular blade I run it at an angle.
Creating a crown with a box blade sounds like work to me since it'll want to transport the material more so than moving it to one side.
Creating a crown with a box blade sounds like work to me since it'll want to transport the material more so that moving it to one side.
Thats the issue i have with a box blade doing it and want to get an angled grader blade
/ grader blade size? #26
Yes it will; that's why I take small bites and make several passes. Trying to build a crown with one pass is a disaster.
A 3-pt hitch, 3-way grader blade works well. I have an old Ford 6' grader blade that also has 2 different off-sets to move the blade 1' or 2' to each side.
I had its use down pat when I used the MF135, but this MF451 is twice as big and feels clumsy by comparison. It's gonna take a while to re-learn how to do some things.
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
HARDEE 6' BOX BLADE (A63291)
HARDEE 6' BOX...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2024 Teagle Tomahawk 8500 (A63688)
2024 Teagle...
2018 VOLVO SD115B PADFOOT ROLLER (A64279)
2018 VOLVO SD115B...
KBH 750 GALLON NITROGEN APPLICATOR (A63291)
KBH 750 GALLON...
