Grader Blade Help
   / Grader Blade Help #1
Panzer315
Massey Ferguson GC 2610 TLB
Looking for a grader blade to use with my Massey Ferguson GC 2610 TLB. Any suggestions or tips?
Thanks!
   / Grader Blade Help #2
They'r ok for light snow plowing or knocking down a pile of gravel, or scraping out the barnyard for little $$, but that's really about all they can do. Don't expect to level a hillside. As for make or model, just get one a little wider than your machine and look for strudy components. What is your expected use?
Now the bigger (heavier) blades that fit up to a 80-100 hp tractor with multi angling abilities will cut a pretty good ditch.
   / Grader Blade Help
My intention is to use it for general gravel road maintenance and such.
From iPhone To Tractor-By-Net
   / Grader Blade Help #5
What do you plan on doing on the road. Filling holes, crowning it, widning.. A box blade will rip up the material better than a blade but you can't angle a box blade like you can a grader blade. I use my blade for road maintinace and have no complains.
   / Grader Blade Help #6
I have 2 rear blades, one heavy and one light. I like the light one for pulling the gravel back into the road. I angle with just a little tilt go down one side and back on the other. Then turn it backwards go down the middle. Done!! The heavy blade diggs in and I only use it to cut a ditch. It's hard for me to control for just pulling stuff back into the road, it pulls up to many big rocks. Just make sure you get one wide enough when it is angled it covers your tires about 6 or 8".
   / Grader Blade Help
I can certainly see where one could use a box blade as well as a grader blade. Therein lies the ultimate answer...each implement serves its purpose. In my case a grader would be of most use most of the time. A box blade would certainly have its uses but would be something I look into later (unless I find that money tree)!
Anyway, I appreciate the info and links all have provided!
Looking for a well built grader to help with material movement. Need the ability to tilt and angle. Otherwise I would just use the loader.
Thanx!
   / Grader Blade Help #9
I don't know your area but I found that you need curl to effectively move snow. No curl and it will steer your rears right off the road.
   / Grader Blade Help #10
Yes, if the blade is straight up and down then it's like pushing against a wall. You can adjust your toplink to increase/reduce the curl.
Large Metal Rooster Lawn Art (A51694)
Large Metal...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
TRUCKING INFO (A50775)
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53473)
JOHN DEERE ROW...
