Grade-to-1 Tilt Meter From R&B Mfg.
   / Grade-to-1 Tilt Meter From R&B Mfg. #1
Muhammad
Administrator
Moderator
San Diego, CA
None currently
Greetings,
We have just published R&B's Model 006 Grade:1 Tilt Meter for sale through TractorByNet.com.
The 006 offers a grade:1 scale useful for landscapers, earth movers, and grounds care users. Building a pond? Driveway? Riding trails? New lawn? Rebuilding a lawn? With an 006 Grade:1 Tilt Meter, you can achieve the perfect grade each and every time.
Click the image for complete details, pricing, and to order:
As with all products we sell through TractorByNet.com, this item has a 100% money-back guarantee and a 1-year warranty.
   / Grade-to-1 Tilt Meter From R&B Mfg. #2
Muhammad:
I enjoy your web site. Great idea! Why is the meter in calibration of 1-6? What does that mean in terms of grading vs if it was in degrees?
   / Grade-to-1 Tilt Meter From R&B Mfg. #3
Hi SCDolphin,
Slopes are sometimes read in grade to 1 rather than degrees.
Many reasons. Erosion control is common reasons. Different
soils will erode or "slide" at different angles. A loose sandy
soil will erode at much less angle than clay. Many of the
highway dept. engineers I deal with will test soil when
designing a highway and right of way. A loose soil may require
a 5-to-1 grade.(11.31 degrees). to keep from eroding. Where
a more solid soil like red clay may not erode until slope is
at a 3-to-1 grade.(18.43 degrees.) Many landfills I sell to use
a 3-to-1 grade as side slope of dump. Seems water will run off
at a steeper slope, but will tend to soak in at a 3-to-1 or less
slope. Most highway depts. use a 3-to-1 slope as a safe
side slope limit for their mowing tractors. Below is a graph
showing grade vs. degrees vs. percent of slope.
9.46 degrees=6 to 1 grade=17 percent.
11.31 degrees=5 to 1 grade=20 percent.
14.04 degrees=4 to 1 grade=25 percent.
18.43 degrees=3 to 1 grade=33 percent.
26.57 degrees=2 to 1 grade=50 percent.
45 degrees=1 to 1 grade=100 percent.
Hope this helps.
Rick
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
(1) 330 GALLON POLY TOTE W/ CAGE (A51248)
(1) 330 GALLON...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
Kubota ZG327 (A50120)
40' CONTAINER (A51248)
