GPS Tracker?
/ GPS Tracker? #51
I put my light bar on the rops, used a couple pieces of angle and a couple exhaust clamps that I slid rubber hose over to make a bracket and clamp it down. Mostly because of what I had laying around the garage and scrap pile
/ GPS Tracker?
Do you have any problems when you look back? I am worried about glare when looking back. Had that problem with my old Kioti that I have lights mounted on the rops. And the bar was higher then that of the Kubota.
/ GPS Tracker? #53
Not with my setup. Not sure how that would be likely either, unless you were plowing reflective snow in the dark. The lights up high pointed down & behind don't have anything but the ground to reflect off of. Maybe a shiny implement?
/ GPS Tracker? #54
I don't have a problem with glare. I would guess maybe just aim the light up/out a little more
/ GPS Tracker?
It was direct light from the lights themselves that was blinding. Maybe I had them pointing down to far. When I get a chance I'm going to pull it into the big shop and play with the placement before I do anything to drastic.
/ GPS Tracker? #56
You use just the one light? It looks like it should produce plenty of light. Also, did the bracket come with it? Or did you fab that up?
Yes, and it works very well. The bracket is a piece of aluminum and a square trailer bolt.
/ GPS Tracker?
Looks good.
The biggest problem I have is where I store my tractor I only have a 7' door. So I can't keep my rops up all the time.
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
