Oil & Fuel governor oil change
/ governor oil change #1
jinmared
Goldendale,Wa
Jinma 354 fwd
What kind of oil should be used in the governor and injection pump?
/ governor oil change #2
I use 10w40 in the injection pumps on Jinmas
Ronald
Ranch Hand Supply
/ governor oil change #3
One man's opinion only, but I use ISO100 compressor oil. When anything - including diesel fuel - is compressed, heat is generated. One of the byproducts is carbon. Compressor oil is formulated to suspend the otherwise unfiltered byproducts of compressed fuel delivery.
//greg//
/ governor oil change #4
I thought compressor oil was non detergent.. and thus didn't suspens debri.. vs detergent oil.. that is designed to suspend debri, so that it can be removed in the filter.. etc.
(Aside from that.. I'm guessing any decent oil in the injector sump will be good.. etc.. )
Soundguy
/ governor oil change #5
We use 5W-30 as a default in most of our service area, New England. Only
a couple of complaints from guys in far Northern Maine about slow slew rates
on the throttle when she first starts up on very cold days. I suggest a light
machine or compressor oil and thats seems to do it. Remember there are no
by products of combustion in the pump.
Cheers
Graham
Bolton Power
/ governor oil change #6
I agree a ISO grade compressor oil is better suited for the need. Engine oil is not needed because there is no combustion contamination to deal with, only lubricating properties are needed.
/ governor oil change #7
You are correct, but one of the properties of the compressor oil formula IS to suspend carbon to prevent buildup on the valves. A compressor can't compress if the valves won't close. But I can see how that might sound like detergent action.
//greg//
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
2015 International 4300 Elgin Broom Bear Sweeper Truck (A64556)
2015 International...
Ground Protection Mats (A64194)
Ground Protection...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
